Mosfets on a mobo usually don't lay flat enough to use Tpaste. So the Tpads are most common on mosfets and Vregs. Same for VRAM usually.
Edit now home.
Chipset cooling meaning the Mobo Mosfets or the NB/SB on the Mobo? If the NB/SB then paste is used. If the Mosfets I have always seen Tpads. ...
total thread jacking...
so then... my aux temp, which i thought was the soutbridge, has been running hot... 52-55c
ALL THE TIME; even after all night at idle while i sleep. i felt around the board, the heatsinks around the CPU area are cool; the southbridge heatsink is warn (but not 50c warm)...
what would you do? re-tim the southbridge chip? add a small fan/blower to the southbdrige?
Not really. As long as you have an intake fan blowing somewhere in the region it'll be fine. I have a tiny sliver of a heatsink on my Z68 board's ICH/SB and it works fine with case airflow.Couple of questions if I may...
- Is SB on Z77 heating enough to warrant removal of the tpad and replacement with tpaste?
You could add some small VRM heatsinks to the VRM chips if you're concerned about it, or you want to go beyond a minor overclock.- Should I think about adding heatsink on upper mosfets and VRM on Asus P8Z77-M? There are no holes in PCB so heatsink would need to be glued I guess, but that means I can't use tpad.... any ideas?
