- Aug 27, 2003
- Mississauga, Ontario
I bought the 1090T BE hexcore cpu, the new 125W one (not new anymore I know). I play on o'cing it to about 4ghz which should be ok, with either staying at 200mhz chipset or going to 250 which I heard is ok with memory and is about 1-2% increase by itself with doing no damage.
But, I have absolutely no need for crossfire or dual video cards, not now, not in the future, so I don't know why I should spend $200+ on a 890FX, unless there are clear reasons for it.
I also don't need onboard video.
So, is there an alternative for me in the 800 series boards? Someone somewhere mentioned to someone else that since the latter is not interested in two x16 pcie slots he should consider the 870 chipset, so what is that about?
I need about everything else that comes on a top 890FX board such as the UD5 GB, basically a couple USB 3.0 ports, and SATA 3, if it has that, I'm happy, and perhaps an eSATA.
Does anyone have any suggestions? Naturally the board has to overclock well, and do all that, it just doesn't need to support full x16 crossfire (it probably will have two pci-e slots i know, but only one has to be x16 is what I'm saying, I will never run a dual card system, one high end card with such a system is more then enough for 1920x1200).
Please help me save some money, or give me a reason why I must go with the 890FX if I indeed must.
The board also doesn't need to support huge memory numbers, I'd be happy with getting 1600 o/ced (to that, not from that), every test I found shows a very tiny percentage increase when going to 2000, and none if latencies have to be increased. I just want good ram that has low latencies and will O/C to 1600 to be happy.
