CM 612, CM V6 GT, Noctua D14
kingp0dd
Good day!
I'm planning to OC an i5 2500k to around 4.2-4.5ghz, and I wanted a good HSF that would keep it cool and hopefully make it last longer.
Here's my setup if it matters:
CPU: Intel i5 2500K
MOBO: MSI Z68A GD65 Gen 3
RAM: G-skill sniper 2x4 8gb (dual)
GPU: EVGA GTX 560 TI DS Super Clocked or HD7850
PSU: FSP Aurum 700watts
CASE: Corsair Carbide Series 400R Mid Tower Case
MON: Samsung 23\" (S23A300B)
I'm looking at these three HSFs:
Cooler Master (Hyper 612 PWM)
Cooler Master (V6 GT)
Noctua (NH D14)
I know the D14 will outperform the other two, but do I really need it when OCing to just 4.5ghz?
I also heard that a good case airflow is also important, should I just get a cheaper HSF and invest on case fans instead?
The case would be a Corsair 400R. I'm planning to put 2 intake fans on the front, and one exhaust fan on the back. I'm not sure if I can still fit 2 exhaust fans on the top with the D14 installed (it's quite large, yes?)
Would be great to hear opinions regarding the 3 CPU coolers
Thanks!
my daughters rig has the v6gt and it is a rather capable hsf, but is a nightmare to change the chip. prolly the worst retention mechanism I have seen.
I am sure that all 3 are great performers as the v6 should be the bottom of the pile
with a 2500k at 4.5ghz even a coolermaster hyper 212 is a capable choice
Thanks for the info! Looks like I'm going with the D14, just to make sure :D
