I thought that adding a second BladeMaster fan to my Hyper 212 Plus was going to make a difference, but today I installed it and apparently it doesn't at all. My case is a Cooler Master ATCS 840 which is very large with plenty of airflow, including two 230mm fans on top.
To run them together and at the same speed I also bought a Y cable so both fans are connected to the CPU fan connector on the motherboard.
Before I installed the new one, I ran Prime95 for ten minutes using the Maximum Heat setting to compare. It was 48C. After that, I cleaned everything again (I had cleaned everything a few days ago including the Hyper 212 heat sink but I cleaned again just in case) and I installed the second Blademaster, which is identical to the one bundled with the Hyper 212+. I made sure that I installed both with the arrow pointing in the same direction, towards the back of the case, where the other case fan is pulling the air out of the case. Before I closed the case, I verified that both were running fine.
Then I ran Prime95, again on the Max. Heat setting for ten minutes, and I was disappointed to see that the temperature was still 48C (both times according to CoreTemp).
So is there anything else I can do? I mean, other than buying a very noisy fan, which I would prefer to avoid. If I change the direction of the two fans, the hot air being pulled from the Hyper 212+ would blow right on top of the 4 RAM modules, so I'm not so sure that would be a great idea. One thing seems certain though, adding the second fan made absolutely no difference. What are your experiences with two fans in this cooler? Have you achieved a difference in temperature?
