gusgizmo
Disabled
- Aug 10, 2003
- Kona, Hawaii
right now i am starting work on a compact water chiller, with the dimensions of 1 foot cubed. i am going to use a medium sized reseivor, with a txv and approximately 30" of 1/4" copper tubing for the evaporator. i am going to use methyl alchohol at 60% strength as a coolant. the condensor is going to be 1 foot squared, and i am going to pull air through the box with a 11" diameter 120v ac fan. here's a sketch of the setup:
i believe the compressor is 1/2 hp, but am not sure. the refridgerant is r-22, and i have a source for more to refill my system after im done modifying the neccesary components.
in any case, im wondering if anyone has any thoughts
