Where can I find BIOS for a motherboard in an older COMPAQ computer?
The motherboard is labeled "QUIK SILVER2-CMT".
Unmodified CPU-Z output is below:
CPU-Z 1.34.1 said:----------------------
CPU-Z version 1.34.1
CPUID Output
Number of CPUs 1
Name AMD Athlon MP
Code name Palomino
Specification AMD Athlon(tm) XP 1700
Family/Model/Stepping 662
Extended Family/Model 7/6
Package Socket A
Core Stepping A5
Technology 0.18um
Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE
Features
Clock Speed 1458.0 MHz
Clock multiplier x11.0
Front Side Bus Frequency 132.5 MHz
Bus Speed 265.1 MHz
Stock frequency 1466 MHz
L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L2 Cache 256 KBytes, 16-way set associative, 64 Bytes line size
L2 Speed 1458.0 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 64 bits
eax ebx ecx edx
Function 00000000 00000001 68747541 444d4163 69746e65
Function 00000001 00000662 00000000 00000000 0383fbff
Function 80000000 80000008 68747541 444d4163 69746e65
Function 80000001 00000762 00000000 00000000 c1cbfbff
Function 80000002 20444d41 6c687441 74286e6f 5820296d
Function 80000003 37312050 00003030 00000000 00000000
Function 80000004 00000000 00000000 00000000 00000000
Function 80000005 0408ff08 ff20ff10 40020140 40020140
Function 80000006 00000000 41004100 01008140 00000000
Function 80000007 00000000 00000000 00000000 00000001
Function 80000008 00002022 00000000 00000000 00000000
edx eax
MSR C0010015 00000000 00001008
MSR C001001B 00000000 6003D22F
MSR C001001E 00000000 00000107
Chipset
Northbridge AMD AMD-761 rev. A4
Southbridge VIA VT82C686 rev. 40
Graphic Interface AGP
AGP Revision 2.0
AGP Transfer Rate 4x
AGP SBA not supported, not enabled
Memory Type DDR
Memory Size 256 MBytes
Memory Frequency 132.5 MHz (1:1)
CAS# 2.5
RAS# to CAS# 3
RAS# Precharge 3
Cycle Time (tRAS) 6
Bank Cycle Time (tRC) 9
DRAM Idle Timer 8
Memory SPD
DIMM #1
General
Memory type DDR
Manufacturer (ID) Samsung (CE00000000000000)
Size 256 MBytes
Max bandwidth PC2100 (133 MHz)
Part number M3 68L3313CT1-CB0
Serial number 25DCD500
Manufacturing date Week 82/Year 01
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
Timings table
Frequency (MHz) 100 133
CAS# 2.0 2.5
RAS# to CAS# delay 2 3
RAS# Precharge 2 3
TRAS 5 6
Dump Module #1
0 1 2 3 4 5 6 7 8 9 A B C D E F
00 80 08 07 0C 0A 02 40 00 04 75 75 00 80 08 00 01
10 0E 04 0C 01 02 20 00 A0 75 00 00 50 3C 50 2D 20
20 90 90 50 50 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 9D
40 CE 00 00 00 00 00 00 00 01 4D 33 20 36 38 4C 33
50 33 31 33 43 54 31 2D 43 42 30 20 30 43 01 52 25
60 DC D5 00 00 57 38 46 35 32 30 30 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Monitoring
Sensor Chip FFFF FFFFFFFF
PCI Device List
Host Bridge
bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1022
Model ID 0x700E
Revision ID 0x14
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0x90000000
Address 1 (memory) 0x81100000
Address 2 (port) 0x00001418
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Capabilities
AGP Capability
Version 2.0
Status enabled
Transfer rate 4x (max 4x)
Queue lenght 1 (max 16)
Dump
00 01 02 03 04 05 06 07 08 09 0A 0B
02 00 20 00 17 02 00 0F 04 01 00 00
Dump
00 22 10 0E 70 06 01 10 02 14 00 00 06 00 20 00 00
10 08 00 00 90 08 00 10 81 19 14 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 08 1B 00 00 00 00 00 00 09 00 00 00
50 60 00 87 00 4A 8C 01 96 00 00 20 E2 00 00 00 00
60 BD CE A1 85 1B 26 E2 56 00 00 00 00 1B 25 D2 57
70 00 06 04 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 01 00 97 10 03 00 30 0F F5 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10
A0 02 00 20 00 17 02 00 0F 04 01 00 00 03 00 00 00
B0 00 00 02 00 82 00 3F D9 8F FF 04 D8 00 00 00 00
C0 83 07 00 00 83 07 00 08 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x1022
Model ID 0x700F
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x20
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x00
Int. Pin 0x00
Dump
00 22 10 0F 70 07 00 20 02 00 00 04 06 00 20 01 00
10 00 00 00 00 00 00 00 00 00 01 01 20 F1 01 20 22
20 00 80 F0 80 00 88 F0 8F 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0C 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
OHCI FireWire Controller
bus 0 (0x00), device 7 (0x07), function 0 (0x00)
Common header
Vendor ID 0x104C
Model ID 0x8020
Revision ID 0x00
PI 0x10
SubClass 0x00
BaseClass 0x0C
Cache Line 0x08
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xA0100000
Address 1 (memory) 0xA0000000
Subvendor ID 0x1113
Subsystem ID 0x1394
Int. Line 0x12
Int. Pin 0x01
Capabilities
Power Management Capability
Version 1.0
Dump
01 00 11 64 00 00 00 00
Dump
00 4C 10 20 80 06 00 10 02 00 10 00 0C 08 20 00 00
10 00 00 10 A0 00 00 00 A0 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 13 11 94 13
30 00 00 00 00 44 00 00 00 00 00 00 00 12 01 02 04
40 00 00 00 00 01 00 11 64 00 00 00 00 00 00 00 00
F0 10 24 00 00 86 10 00 00 13 11 94 13 00 00 00 00
Ethernet Controller
bus 0 (0x00), device 8 (0x08), function 0 (0x00)
Common header
Vendor ID 0x10B7
Model ID 0x7646
Revision ID 0x30
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x08
Latency 0x20
Header 0x00
PCI header
Address 0 (port) 0x0000FF00
Address 1 (memory) 0xFEBFFF80
Subvendor ID 0x10B7
Subsystem ID 0x7646
Int. Line 0x11
Int. Pin 0x01
Capabilities
Version 1.0
Dump
01 00 01 76 00 00 00 00
Dump
00 B7 10 46 76 07 00 10 02 30 00 00 02 08 20 00 00
10 01 FF 00 00 80 FF BF FE 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 B7 10 46 76
30 00 00 00 00 DC 00 00 00 00 00 00 00 11 01 0A 0A
50 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 76
Serial 16550 Controller
bus 0 (0x00), device 9 (0x09), function 0 (0x00)
Common header
Vendor ID 0x12B9
Model ID 0x1008
Revision ID 0x01
PI 0x02
SubClass 0x00
BaseClass 0x07
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x00001410
Subvendor ID 0x12B9
Subsystem ID 0x00A2
Int. Line 0x13
Int. Pin 0x01
Capabilities
Version 1.1
Dump
01 00 02 EC 03 40 00 A0
Dump
00 B9 12 08 10 00 00 10 02 01 02 00 07 00 00 00 00
10 11 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 B9 12 A2 00
30 00 00 00 00 DC 00 00 00 00 00 00 00 13 01 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 01 00 02 EC
E0 03 40 00 A0 00 00 00 00 00 00 00 00 00 00 00 00
Audio device
bus 0 (0x00), device 10 (0x0A), function 0 (0x00)
Common header
Vendor ID 0x1274
Model ID 0x1371
Revision ID 0x09
PI 0x00
SubClass 0x01
BaseClass 0x04
Cache Line 0x00
Latency 0x20
Header 0x00
PCI header
Address 0 (port) 0x00001080
Subvendor ID 0x1274
Subsystem ID 0x1371
Int. Line 0x10
Int. Pin 0x01
Capabilities
Version 1.1
Dump
01 00 22 06 00 00 00 00
Dump
00 74 12 71 13 05 00 10 34 09 00 01 04 00 20 00 00
10 81 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 74 12 71 13
30 00 00 00 00 DC 00 00 00 00 00 00 00 10 01 0C 80
D0 00 00 00 00 00 00 00 00 00 00 00 00 01 00 22 06
PCI to ISA Bridge
bus 0 (0x00), device 20 (0x14), function 0 (0x00)
Common header
Vendor ID 0x1106
Model ID 0x0686
Revision ID 0x40
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1106
Subsystem ID 0x0686
Int. Line 0x00
Int. Pin 0x00
Capabilities
Version 1.1
Dump
01 00 02 00 00 00 00 00
Dump
00 06 11 86 06 87 00 10 02 40 00 01 06 00 00 80 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 06 11 86 06
30 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00
40 08 01 00 C0 00 80 62 A6 01 00 44 00 00 00 F0 F3
50 02 06 04 00 00 00 00 00 00 06 FF 00 50 00 00 00
70 00 00 00 00 20 20 22 D0 00 00 00 00 00 00 00 00
80 00 00 00 00 00 0D 00 00 00 60 00 00 00 00 00 00
C0 01 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 42 00 00 00 00 00 00 00 00 00
IDE Controller
bus 0 (0x00), device 20 (0x14), function 1 (0x01)
Common header
Vendor ID 0x1106
Model ID 0x0571
Revision ID 0x06
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x20
Header 0x00
PCI header
Address 4 (port) 0x00001400
Subvendor ID 0x1106
Subsystem ID 0x0571
Int. Line 0x00
Int. Pin 0x00
Capabilities
Version 1.1
Dump
Dump
00 06 11 71 05 07 00 90 02 06 8A 01 01 00 20 00 00
20 01 14 00 00 00 00 00 00 00 00 00 00 06 11 71 05
40 0B A2 09 3A 15 10 C0 00 41 41 A8 41 30 00 FF FF
50 E4 E1 07 E0 14 00 00 00 A8 A8 A8 A8 00 00 00 00
60 00 02 00 00 00 00 00 00 00 02 00 00 00 00 00 00
70 02 01 00 00 00 00 00 00 02 01 00 00 00 00 00 00
80 E8 3E 8B 01 00 00 00 00 A8 12 83 01 00 00 00 00
D0 06 00 71 05 06 11 71 05 00 00 00 00 00 00 00 00
USB Controller (UHCI)
bus 0 (0x00), device 20 (0x14), function 2 (0x02)
Common header
Vendor ID 0x1106
Model ID 0x3038
Revision ID 0x1A
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x20
Header 0x00
PCI header
Address 4 (port) 0x000010C0
Subvendor ID 0x0925
Subsystem ID 0x1234
Int. Line 0x0B
Int. Pin 0x04
Capabilities
Version 1.1
Dump
Dump
00 06 11 38 30 07 00 10 02 1A 00 03 0C 08 20 00 00
20 C1 10 00 00 00 00 00 00 00 00 00 00 25 09 34 12
30 00 00 00 00 80 00 00 00 00 00 00 00 0B 04 00 00
40 40 00 01 00 C6 00 30 40 00 00 00 00 00 00 00 00
60 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 01 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
bus 0 (0x00), device 20 (0x14), function 3 (0x03)
Common header
Vendor ID 0x1106
Model ID 0x3038
Revision ID 0x1A
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x20
Header 0x00
PCI header
Address 4 (port) 0x000010E0
Subvendor ID 0x0925
Subsystem ID 0x1234
Int. Line 0x0B
Int. Pin 0x04
Capabilities
Version 1.1
Dump
Dump
20 E1 10 00 00 00 00 00 00 00 00 00 00 25 09 34 12
40 40 00 01 00 02 00 36 34 00 00 00 00 00 00 00 00
Bridge device
bus 0 (0x00), device 20 (0x14), function 4 (0x04)
Common header
Vendor ID 0x1106
Model ID 0x3057
Revision ID 0x40
PI 0x00
SubClass 0x80
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1106
Subsystem ID 0x3057
Int. Line 0x00
Int. Pin 0x00
Capabilities
Version 1.1
Dump
Dump
00 06 11 57 30 00 00 90 02 40 00 80 06 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 06 11 57 30
30 00 00 00 00 68 00 00 00 00 00 00 00 00 00 00 00
40 20 88 49 00 00 00 00 00 01 EE 00 00 02 00 00 00
50 00 7F FF 00 00 04 00 00 00 DF FF 00 06 11 57 30
60 00 00 00 00 00 00 00 00 01 00 02 00 00 00 00 00
70 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 01 EC 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 40 00 00 00 00 00 00 00 00 00
VGA Controller
bus 1 (0x01), device 5 (0x05), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0110
Revision ID 0xB2
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x00
Latency 0xF8
Header 0x00
PCI header
Address 0 (memory) 0x80000000
Address 1 (memory) 0x88000000
Subvendor ID 0x1462
Subsystem ID 0x8826
Int. Line 0x10
Int. Pin 0x01
Capabilities
Version 1.1
Dump
01 44 02 00 00 00 00 00
AGP Capability
Version 2.0
Status enabled
Queue lenght 1 (max 32)
Dump
02 00 20 00 17 00 00 1F 04 01 00 0F
Dump
00 DE 10 10 01 07 00 B0 02 B2 00 00 03 00 F8 00 00
10 00 00 00 80 08 00 00 88 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 62 14 26 88
30 00 00 00 00 60 00 00 00 00 00 00 00 10 01 05 01
40 62 14 26 88 02 00 20 00 17 00 00 1F 04 01 00 0F
50 01 00 00 00 01 00 00 00 CE D6 23 00 0F 00 00 00
60 01 44 02 00 00 00 00 00 00 00 00 00 00 00 00 00
DMI
DMI BIOS
vendor Compaq
version 786K2
date 12/05/2001
DMI System Information
manufacturer Compaq
product Compaq PC
version CTOAAAAA
serial ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
UUID 30313035-30313031-30303136-44373835
DMI Baseboard
vendor Compaq
model 07BCh
revision None
serial None
DMI System Enclosure
manufacturer Compaq
chassis type Mini Tower
chassis serial None
DMI Processor
manufacturer AuthenticAMD
model AMD Athlon XP 1700
clock speed 1466.0MHz
FSB speed 133.0MHz
multiplier 11.0x
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 1536MBytes
max# of devices 2
DMI Memory Device
designation DIMM1
format DIMM
type DDR
total width 64bits
data width 64bits
size 256MBytes
DMI Memory Device
designation DIMM2
format DIMM
type DDR
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI2
type PCI
width 32 bits
populated yes
DMI Extension Slot
designation PCI3
type PCI
width 32 bits
populated yes
DMI Extension Slot
designation PCI4
type PCI
width 32 bits
populated yes
DMI Extension Slot
designation PCI5
type PCI
width 32 bits
populated yes
Software
Windows Version Microsoft Windows 2000 Professional Service Pack 4 (Build 2195)
DirectX Version 9.0c
