- Jul 15, 2014
So recently I won the hwbot drawing for the CM Seidon 120V and it arrived yesterday and I decided I would do my own little comparison between it and my 212 Evo just to see what kind of difference between the two. With the two being budget coolers for both air and water I wanted to see for sure how much if any difference there was.
So my tests consisted of 20 minute prime 95 blend tests on both with push/pull configurations as well as with only one fan in a push configuration. Waited 1 hour between all tests.
FX 6350 overclocked to 4.6GHZ, Ambient temperature stays around 75 F in my house
Fans used for all comparisons http://www.newegg.com/Product/Product.aspx?Item=N82E16835103069
My build is in my signature with components used for this comparison.
So I had started off with my 212 Evo in a push/pull configuration and my Idle temps were 30C and after 20 min on prime 95 load temps would go to 60c and they would never go above there.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099&cm_re=212_evo-_-35-103-099-_-Product
Once I had those numbers I moved onto the single fan in a push configuration to the back of the case to the 140mm exhaust fan.
With only one fan my idle temps stayed the same at 30C but full load temps hit 64C. Didnt think one fan on it made that big of a difference.
Now that I had my numbers for the 212 EVO I moved onto the Seidon 120v aio water cooler that I got for free. Now first thing I'd like to say about this is the instructions for mounting suck. At first couldn't figure out why it would not get very good mounting pressure. At first I was getting idle temps of 50-60c and was pissing me off. The bracket of this cooler has to line up with the mounting hardware perfectly so that the bracket can slide down over the hardware while you are tightening it.
So after I finally go it mounted I moved onto the testing. First the 120V with only one fan
http://www.newegg.com/Product/Produ...3195&cm_re=seidon_120v-_-35-103-195-_-Product
Ok so with one fan my idle temps were pretty much the same as the other tests at 30c. So no change there. But once it got under load is where I seen slight improvements. At full load temps were at 59C which is a 5c difference between one fan on the 212 evo.
And moving onto both fans on the radiator in push/pull the idle temps were at 29c and full load was 57c.
I will post pictures at a later date seeing that I am at work so itll be a day or so.
212 EVO- 1 fan- 30/64
212 EVO- 2 fan- 30/60
120V - 1 fan- 30/59
120v - 2 fan- 29/57
So for the most part the 120V is marginally better. But with the prices more or less comes down to personal preferance between water and air in my opinion. Both have pros and cons.
212 Evo pro- no pump to worry about failing
120V pro- doesn't necessarily requires the space as the 212 evo seeing as you could mount the radiator where you exhaust fan is on your case
I'm sure there are many more but thats just the ones that pop directly into mind.
120V - 1 fan- 30/59
120v - 2 fan- 29/57
