- Oct 10, 2012
- Secret lair
On your earlier posts, I believe you stated that the 850 was blowing down and onto the CPU. Since hot air wants to go up, it was just cycling the hot air up at the top of the case. This was obviously a bad thing. I'm going to guess that your 750 watt pulls air up and out. Thus the lower heat. The actual temps of both of these power supplies would be nominal. They are both quality units. As such, the major difference would have been the direction of air flow.
I have a full tower case I packed it with lots of fans all spinning slow and silent. I have 2 x 140mm up front AND down low. These pull cool air in. I have a 200mm fan at the top of the case pushing hot air out. I also have another 140mm pushing air out. When thinking of cooling, you want to consider the natural movement of the air. Warm air moves up and cool air is down low. Push/pull air in the same direct. Usually pull in from the front and push out to the back.
With your current case, a fan that fits your dusty slot should do wonders for you.
And as soon as you install fans the whole "hot air rises" statement becomes obsolete
Ive never seen a PSU exhaust through the large fan and INTO case...
not since the late '80's, no
