- Apr 6, 2011
- OH-IO
600MB of free RAM really isn't much. The hard drive is most likely constantly 'loading' because you are using your page file (hard drive space used when you run out of RAM) very heavily. You can try disabling startup items going to Start -> Run -> type 'msconfig' - go to the Start-up tab - uncheck anything you don't need to run at startup (i.e. google notifier, adobe reader, etc). This should help w/ RAM consumption.
If that doesn't work, I would get 2x1GB of RAM to put in the system. Every screen shot you have posted shows your page file being heavily used; that will slow your system down substantially. Since the sector relocation count hasn't gone up on your drive, I'd recommend not replacing your hard drive at this time.
