Hey, quick question about controlling some fans:
I have a Corsair H60 with a push/pull setup of two Ultra Kaze 3000's, with a shroud inbetween the push fan & the radiator.
What I had wanted to do was have it setup as such: Get both kaze's down to about 1500 rpms at idle to reduce some noise but still have a powerful push/pull setup capable of going to the full 3000rpms at full load should temperatures get a little hairy.
So I have the 'pull' Kaze plugged into the 'rear chassis fan' header, which is great as I can bring that one down to as low as 15% of speed or up to full whenever i wish. The problem is the 'push' kaze - it's plugged into the CPU fan header, and it's stuck at 2900 RPMs despite my best efforts to change it.
I'd like to hear any suggestions for trying to get my desired fan setup. The H60's pump is plugged directly into the PSU, I am not allowing the motherboard to control this one. Would it be OK if i plugged the 'push' kaze into the 'front chassis fan' header? Intel's tech. specs say not to do this for this reason:
So when I see something like this I get a little nervous, so I wanted to throw it out to you guys. Any input would be apreciated, thanks!
The processor fan must be connected to the processor fan header, not to a chassis fan
header. Connecting the processor fan to a chassis fan header may result in onboard
component damage that will halt fan operation.
