- Nov 13, 2014
- Hamburg,Germany
Hello folks,
I get straight to the point . I have a rig with these components : Fx 6300 , DDR3 8GB , 1TB HDD, AMD R9 270 and artic cooling 550watt, case: Sharkoon VS3-S
The computer was working perfectly for 3-4 months straight , but suddenly while i wsa playing heavy games it was shutting off. at first i thought it was my PSU , i was skeptic about it even before i get it . So i gave it back and they sent me a new one . but still my computer it was shutting off whiel i was playing . after that i decided to clean my computer inside , remove all dust and renew the thermal paste on the CPU . After that my PC was fine again. After 3 months it started again shutting off . So i came into the conclusion that my problem was the CPU cooler. everytime i has the problem , i was cleaning the CPU cooler and everything worked fine again .
So currently i am thinking to buy a new CPU cooler but i dont have a clue which one is good and which not , and also I am afraid that it doesnt fit in my PC case . Could anyone one of you please suggest me a good cooler that could actually also fit in my case , without have air flow problems and space problem ?
thanks in advance ,
A.K
thanks in advance ,
A.K
