- Nov 16, 2003
- Cleveland OHIO
yea of corse id leave it run outside the case for a good 48 hours.
MadSkillzMan said:...now you used copper tubing as barbs? any final notes on what to do/get before i attempt this? its gonna be a few days b4 i weld it. first i gotta hollow out an old AT case, cut a hole for the rad, cut up the caps etc...
MadSkillzMan said:well i did a run around today guys..no one here carries 2" copper caps. biggest home depot has is 1.5". I did however get female barbs for my rad...they fit it nicely just hafta solder...i got 4 1/2" connectors, tubbing, and the door pulls...i found a 2" alluminum fence pole cap, and it looks way too large ...2" for the cpu cap seems a bit off are you sure you didnt get a 1.5" cap? the morons at lowes didnt have any and took 20mins to checkout 3 people so when i went to go back to home depot they were closed...so...wer about to get blasted with snow, so i guess once the storm clears ill go out and get em...i think the 1.5" caps will work...they guys at both stores told me 1.5" was as big as they go..so..i guess ill just take the brass fitting with me next time and see if it fits before i buy it
sunrunner20 said:If I knew what socket he had it on in the image, I could figure it out from mechanical drawings.
MadSkillzMan said:how did you do that garymator? just 2 same size caps? also, what size?
ghettocomp, cutting your caps down, whatexactly does that serve other than lower profile? i mean what if we just put copper pins in and have it the original size?
the garynator said:i ran into the problem of them not having the thick stock and i decided to use two caps instead of one, it worked out nicely... If you'd like to take a look, the thread link is in my sig... man i feel weird, all you guys test your stuff for so long... i have no patience and slapped mine on after about 30 minutes of leak testing... no leaks and i've had' er running 24/7 since i built it. good luck on your endevours
