purplepanda
- Jul 11, 2012
Hey all, I'm new here, but I figured someone here might have the answer I'm looking for. A few months ago I built my first PC. I bought an Athlon II X3 455 because I heard it was good for unlocking a fourth core, and I also bought an Asus M4A88T-M motherboard. After putting everything together and installing Windows 7 and whatnot, I tried to unlock the fourth core, and it worked without a hitch.
The PC was made for gaming, and I wanted to see if I could overclock it, so I downloaded Coretemp and HWMonitor. The idle core temps without the extra core were pretty low (around 28C), and with the fourth one weren't much higher (32C). Whenever I gamed, they went up to a max of around 50C, maybe a few degrees higher. But I noticed, the CPU reading is always a fair bit higher (40C with three cores). When I start playing games it gets a little past 55C, which I've seen in some places is the max for this particular CPU (I haven't been able to find any info about that from AMD).
I tried a Prime95 stress test, and with four cores the core temps went up to around 50C and the CPU 60C in just a few minutes. The results were a little better with three cores, but in both cases I stopped before the CPU temp got higher than 60C. All of this is without any overclocking.
What I really want to know is, which should I be looking at, the core or CPU temps? There's almost always a ten degree difference there. And also, what's the max temp I should be running this CPU at? I've seen people recommend anywhere from 55C to 72C. I haven't had any issues so far with blue screens or shutdowns, but I'm a little freaked out it's just going to explode and then I'm going to have to start all over.
Specs:
AMD Athlon II X3 455 w/stock fan | Asus M4A88T-M motherboard | Seagate Barracuda Green 1.5 TB HDD | Corsair 8GB DDR3 1333 RAM | EVGA GTX 460 | This case with a Rosewill Green Series 630W Power Supply | I added a 120mm outtake fan in the back (Should I take this out or change the direction? I have one 80mm intake on the side and one 80mm outtake on the top. Thinking about adding two 80mm input fans in the front (in front of the hard drive area), but is there any point with this case? Wouldn't the front panel block all of the airflow?)
Thank you in advance for any help. ~
Specs:
