My 2.4c is set @ 1.55v in the bios, and is running @3.4. CPUZ however reads the voltage @ 1.500, dipping as low as 1.450 and as high as 1.520
the bios is reading the volatge @ around 1.488, with fluctuations
sandra reads the voltage between 1.47 and 1.52
when i up the voltage in the bios (1.575v) in an attempt to clock higher while retaining stability, (3.5ghz), the bios reads an average of a measly 1.525volts
I have an enermax 350w supply (EG-865P), and its feeding my 9800, as well as 6 fans (one 12cm, two 8, one 7, one 6, one 4) Is it overworked?
I have an msi 865pe rev. A2 with latest bios version, could it be the problem?
My temps are fine, 28c as per sandra and 30c as per msi (idle and water cooled).
System posts @ 3.73(didnt try any higher as its pointless), however if i try to raise the voltage over the stock suggested 1.525 volts on the bios, (which is more like 1.45volts effective), i cant post past 3.5. Again my temps are fine so this whole behiavior is a mystery to me. More importantly, the fluctuations and starvation of my core voltage has been worrying me for almost a year now.
Ram is way under spec @ 378mhz (PC3700), as it would need to run @ 454 on a 5:4 multiplier, and i do plan on pushing the cpu further.
Any suggestions? And sorry for the looooooong post.
