- Jan 12, 2009
hey guys!!!
Time for my new PC build, so I'm here with some questions.
I've done a bunch of googling and watching of install guides, and the results seem to be mixed about 50/50.
I purchased an additional 200mm fan for the roof of my HAF-X. So I now have 2-200mm fans installed.
Everything I've read says that it is best to install the H100 with a push/pull setup. This means 2-120mm fans on each side.
I'm looking strictly for a performance related answer, ignoring the obvious noise concerns and what not.
Would I be at a disadvantage utilizing 4 fans on the H100, and then mounting it to the roof of my HAF-X, which then has 2-200mm fans on top. I would think I could use 2 fans on the underside of the radiator pushing, and have my 2-200mm fans on the roof pulling.
But I'm just not sure what would be best for my overclock.
If 4 fans + 2 fans on the roof, is indeed the way to go. Do you guys have any recommendations for fans? I've always went with Scythe S-Flex in the past, but they have been discontinued and replaced with the Scythe Kama Flow 2.. I was looking into getting 4 of these for mounting on the h100. Am i looking at the wrong fans since the H100 has a built in fan controller?
New rig
- GTX 670 2GB
- Core i7 3770K
- Gigabyte GA-Z77X-UP5 TH
- G.SKILL Trident X Series 16GB (2x8GB) DDR3 2400
- OCZ Vertex 4 128GB
- AS5
- Corsair H100
- HAF-X
- Antec Signature Series 650W (PSU from old rig)
let me know what you think
Thanks in advance!!!!!
New rig
- GTX 670 2GB
- Core i7 3770K
- AS5
- Corsair H100
- HAF-X
