Hello all, first time poster here.
I recently build my new PC
Spec's
ASUS TUF X99 Sabertooth MB
Intel i7 6800k Cpu
32Gb Corsair Vengeance 2400
Samsung 950 Pro M.2
Corsair H115i AIO Cooler ( replaced the stock corsair fans with Noctua nf 12 )
and other SSD drives
My quest for now is what is the best fan connection for the cooler, as in should I use the fan header cables from the pump and use Corsair Link ( this is what I have it as atm ), or use the fan headers on the MB. The one ones on the MB are a little confusing atm, the pump I have plugged into the CPU header ( not the CPU_OPT ). If I use headers on the MB for the fans do I plug them into the CPU_OPT header and what settings in the BIOS do I use.
I know this maybe a little obscure or even a silly question but any advise would be appreciated.
Thank you.
Spec's
Intel i7 6800k Cpu
Samsung 950 Pro M.2
Thank you.
