- Mar 13, 2011
- Chaparral, New Mexico
Alright well having problems with my H60. Temps on my 965be are over 55c during prime at 1.38v.
Is it possible to have the block to tight? I noticed I tightned so much that the tabs acctualy bent downwards tords the mount a bit.
The paste is Cooler Master HTK-002-U1 Thermal Compound. Mayeb a better paste?
And maybe my fan combo. I have the rad mounted directly to the case, with the 120mm suppliedon the inside blowing air through and out. Then a 140mm on spacers on the outside of the case.
Oh and have 4x120mm coller master sickle flow fans on the door blowing air in. Top fan is exhaust.
