- Apr 10, 2005
- Philippines
So I had an older S939 HTPC die on me. For the whole story look here.
Basically, my S939 mobo died on me, there have been none for sale locally since August and I was stuck. Luckily, a friend gave me his old MSI K8N Neo4 Platinum. So now the specs of it are:
Zalman HD160 case
Silvertone Strider ST60F
2x512mb OCZ gold PC3200
AMD x2 4200+
MSI 8600GT
WD 250gb sata
Bluegears Ensipre
2 x pvr-500s
If you skipped the other thread, all of these parts, besides the mobo my friend gave me, have been tested thoroughly and work fine.
So, when my friend gave me this mobo, he told me that it has a problem. The problem was that the mobo would not recognize the keyboard and mouse sometimes. To fix this, I would have to unplug the box, let it sit and plug it back in. Sometimes, he told me, I would have to let it sit for a few mins before the keyboard and mouse would be recognized.
I quickly slapped the box together, as I had guests over the holiday. Now I've had a bit of time to see how it works and I have the following problems:
1) The keyboard/mouse issue my friend mentioned. To be honest, I don't have a keyboard or mouse plugged into this box, so I only experienced it once when I was restoring the disk image onto it. Its a HTPC, and a well configured HTPC doesn't need a keyboard and mouse IMO (just a remote and, maybe, gamepad). When it happened, I tried PS/2 and USB neither would be recognized. I had to unplug, let sit and replug.
2) On boot, it gives me the bios boot device selector menu sometimes. I can choose the HD and it will boot but I have only 1 HD and a DVD drive, its set to boot from the HD, etc. So this is some deficiency with the mobo. Unplug, let sit, etc will make it go away. Its really irritating because I don't have a keyboard and mouse on the box!
As I said, now I have some time to look at it and I have. This board has a heatsink on the Nforce4 chip with a tiny fan. It looks exactly like this:
The thing is, the fan doesn't spin anymore. The board is probably so dusty (my friend must've used it hard) that the fan is too choked to spin. An overheating Nforce4 chip would explain why letting it sit would make the problems go away.
So my questions are:
A) Can an overheating Nforce4 chip cause these kinds of problem?
B) How do I get an accurate temperature for the nforce4 chip? I don't have temp probes . I used to have a gage, but it broke and I have no idea where to get one locally.
C) Once I get a temp reading, what should it be? What is overheating?
D) What can I do to get the fan to spin again? Axel grease? What kind? Where do I put it?
Thank you!
Zalman HD160 case
AMD x2 4200+
MSI 8600GT
WD 250gb sata
Bluegears Ensipre
2 x pvr-500s
Thank you!
