- Feb 23, 2011
- Toronto, Canada
You should read the stickies.
Off the cuff I would recommend getting as much radiator as will fit in your case, swiftech rads are good, so are alpha cool. Swiftech mcp35x is a great pump. Primo-chill advanced lrt tubing, I like 3/8 x 1/2 but any size will do as long as you buy the appropriate fittings. As for fittings I stick with bitspower compression fittings. Also I use bitspower reservoirs but reservoir choice doesn't impact much. Just make sure that gravity Compels water to flow from the reservoir to the pump inlet. Gt ap15 are good for most water-cooling loops. Couple blocks are mostly personal preference. The ek supreme and xspc raystorm are two good choices at the opposite ends of the cost spectrum.
I'm in Toronto and I buy whatever I can from dazmode. If he doesn't have it I buy from sidewinder and then frozen cpu. Never ship with ups when ordering from the USA, import fees are up to 70 percent of th order cost sometimes. Use usps
