- Sep 23, 2011
So I am looking around at reviews a decided it would be nice to hear some opinions
Now I plan to buy an aftermarket cooler and have about $120 to spend on it.
I live in a hot enviroment but will be using AC which will bring the room temp to about 25C, but if not it can reach 36 degrees (I won't be doing much if i run the PC without AC).
So what options do I have? What would be best but will also look great (I like the look of the H100 will it be find with a higher ambient room temp?^_^
I don't really plan to overclock as of now but might in the future.
So long story short; what is the best cooler to get for $120?
Jawn.
-My system:
HAF X (4x200mm, 1x140mm)
Corsair HX850
i7 2600k
2x ASUS GTX 560ti
ASUS XONAR Essence STX
16GB XMS Corsair memory
OCZ 120 Agility 3, 1TB WD Back, Seagate 500GB.
ASUS P8-Somthing V PRO
Jawn.
-My system:
Corsair HX850
i7 2600k
2x ASUS GTX 560ti
