This is my first post and I do hope that I have made it in the right section.
I have a problem with my CPU getting dangerously (as far as I know at least, 56 degrees celsius) hot. First things first, my specs:
CPU: AMD Phenom II X6 1100T
CPU Heatsink: ZALMAN CNPS9900MAX-R 135mm
RAM: 16GB G.SKILL Ripjaws X Series 240-Pin DDR3 1600 (PC3 12800) Model F3-12800CL9D-8GBXL
Motherboard: ASUS Crosshair IV Extreme Extended
Video Card: XFX Radeon 6970 2GB
HDD: 1x Western Digital Green 1TB
4x Segate 1TB
PSU: Silverstone 1000 watt
Case: Silverstone Raven 01
Monitoring Software: ROG AI Suite II
The problem started when I went from my old Radeon 6570 to my new 6970. Almost immediately after installing it I noticed that my cpu temps had risen ~10 Celsius putting my temperatures into the high 50 while playing any game at all. To fix this I moved my gfx card as far away from my cpu as possible and increased the fan speed from 20% to 50%. These settings have worked until I recently started playing Battlefield 3. Within 20 minutes of starting the game I got a warning saying my CPU temps had hit 56 degrees, so I popped off the side of my case and they dropped to 50 degrees. This led me to believe that I had an airflow problem of some sort. I decided to test this by running Prime 95 x64 bit with my computer chassis closed. After 20 minutes, I was holding steady at 53 degrees. So... the CPU gets pretty warm maxed, and if my GFX card is pumping out heat too, things get a little too hot inside my computer. What I want to know, is how, if at all, I can improve my current setup so that I do not have to crank my GPU fan up to 100% and make my computer sound like a small jet.
Here are pics of my setup:
http://imageshack.us/photo/my-images/38/img0043gd.jpg/
http://imageshack.us/photo/my-images/859/img0042kh.jpg/
http://imageshack.us/photo/my-images/641/img0041rf.jpg/
http://imageshack.us/photo/my-images/696/img0049qg.jpg/
http://imageshack.us/photo/my-images/190/img0046ci.jpg/
I am in the process of swapping my Zalman CNPS heatsink for a Corsair H60 in a push pull setup on the top fan.
Thoughts?
4x Segate 1TB
Thoughts?
