- Jun 24, 2010
Hey, just got my build up and running the other day. Everything is stock as of now but i am noticing some squealing noises coming from the MB which transfers through the speakers depending on how loud they are turned up.
Did some searching and found it is cause by CPU Enhanced Halt (C1E) being enabled (only does it when the system is idling as it lowers the voltage and multipliers). When i disable it, there is no noise or interference what so ever.
In my case, with a stock system, what are some pros and cons of having it enabled vs disabled? I did notice my idle temps we up about 2-3C degrees with it disabled. I also have the CM V8 HSF.
Thanks!
Thanks!
