- Thread Starter
- #21
Are you able to show us some images of your setup?
The grill on the fan is usually the exhaust side of it where the open part is intake.
Also, have you gone into the BIOS or OS software to see what the settings of the pump or any readings coming from it? Assuming you have the pump connected via CPU Fan Header. You should feel the tubing of the AIO and the pump top and see if they are warm or presumably very hot. Also, some vibration from the pump top at least tells you it could be working.
The tubing is hot. both tubes. I would expect them to be colder?
