im RTFMing... "Thermal Interface material is toxic. DO NOT eat the Thermal Interface material."
damn..always wanted to eat it : /
im in bios now.. stuffs glowing in pretty lights on the mobo and other devises lol wish had a case with window and in a visible place
I'd leave all of the voltages on auto except the cpu and ram voltage and anything else in the guide I don't remember off the top of my head. Those you want to manually set at the default levels and only increase it when you get unstable. You also want to set your clocks manually, obviously.
Do you really want to leave uncore, vtt, and QPI on auto? Won't they get bumped up to dangerous levels if left on auto as you raise BCLK?
I've got no direct experience w/ i7, but just wanted to make sure for the sake of the OP, and anyone else reading.
talking about defautl values: somehow in my BIOS (with latest updates etc.) i cant set memory to exactly 1.65v because it only allows 0.0650 increments. i can set some value just slightly under 1.65v of course. should that do?
auto settings at which im running it right now (was busy with windows, didnt OC yet) are 1066 clock (while the kit is meant for 1333) and about 1.5v, so its undervolted/underclocked
will raising it to 1333 and 1.65v give me some real world performance gain?
might i experience more stability issues at this clock/voltage then on 1333/1.65v?
im really dont mind benchmarks, just noticeable real world performance.
You should not need to raise the Bclock from its default value in order to have your memory running at 1333, you just have to change the memory multiplier.
hm nevermind that.. already on my way there.. now watching out for temps.
this is why tell me please:
- whats a good full-load temp for the 980x,? ("good" meaning "will allow me to load it for years and wont die anytime soon
- is IOH temp of 60 celsius on load a good one?
- what is CPU PLL and why does it want 1.8v by default? i googled much, but nowher eit actually says wtf CPU PLL is
and why is CPU PLL at 1.8?
