- Nov 29, 2011
My fans don't seem to be responding to an increase in temperature. On a small FFT test on Prime95 (not overclocked), my CPU and System temps shot up to over 80c in about five seconds while my fan speeds didn't change.
Here's CPUID Hardware Monitor's report on idle:
Hardware monitor Winbond W83667HG
Voltage 0 1.25 Volts [0x9C] (CPU VCORE)
Voltage 1 1.74 Volts [0xDA] (VIN1)
Voltage 2 3.42 Volts [0xD6] (+3.3V)
Voltage 3 5.14 Volts [0xD6] (+5V)
Voltage 4 11.77 Volts [0xD3] (+12V)
Voltage 6 0.56 Volts [0x46] (VIN6)
Temperature 0 56°C (132°F) [0x38] (SYSTIN)
Temperature 1 57°C (133°F) [0x71] (CPUTIN)
Temperature 2 53°C (126°F) [0x69] (AUXTIN)
Fan 0 1767 RPM [0xBF] (SYSFANIN)
Fan 1 1962 RPM [0x2B] (CPUFANIN0)
Fan 3 1500 RPM [0xE1] (AUXFANIN1)
And under load:
Voltage 0 1.26 Volts [0x9D] (CPU VCORE)
Voltage 6 0.53 Volts [0x42] (VIN6)
Temperature 0 81°C (177°F) [0x51] (SYSTIN)
Temperature 1 82°C (178°F) [0xA3] (CPUTIN)
Temperature 2 56°C (131°F) [0x6F] (AUXTIN)
Fan 0 0 RPM [0x0] (SYSFANIN)
Fan 1 2009 RPM [0x2A] (CPUFANIN0)
Fan 3 168750 RPM [0x1] (AUXFANIN1)
You may notice the readings for SYSFANIN and AUXFANIN1 are a little funky. SYSFANIN bounces between 0, ~888 to the max of 168750. AUXFAN does the same thing. It doesn't seem to be affected by the stress test -- it just flips through 0, max readout, and a normal RPM. I'm not sure what that means, but it's something I'd like explained. CPUFAN doesn't move much at all, but it's a stable reading.
Any advice on what steps to take next?
[Oh, and one wrinkle: I ran these tests on Windows XP (32 bit). A few weeks ago I ran it on Windows7 and remember the CPUFAN speed going up, but having no impact on CPUTemp.]
Thanks!
System:
CPU INTEL|CORE I5 750 2.66G R
ARCTIC COOLING Freezer 7 Pro Rev.2 92mm Fluid Dynamic CPU Cooler
MOBO: MB ASUS P7P55D EVO P55 LGA1156 R
PSU: PSU ROSEWILL| 700W RV2-700 RT
VGA: ASUS|ENGTS450 DIRECTCU/DI/1GD5 (NVIDIA GTS450) x 2 (SLI)
MEM: 2Gx2|GSKILL F3-16000CL9D-4GBPIS x 2 (8G total)
And under load:
Thanks!
System:
