CPU Temp. Reading same as Case Temp.
madman22
My CPU Temp. is Reading the same as the Case Temp.
Is this possible with good air cooling an A64 3200? Or do i just have some errors in temperature readings? its like this in bios and in Asus Probe.
current temps : 32C
btw, thats about how warm it is outside. i got AC.
The reading is possible, the actual temperatures being the same are not.
Temp probe calibration notoriously sucks, and depending on the airflow around your socket and your particular mobo and bios version, that is just the reading you get with your setup. The relative changes between idle and load may mean something, but the actual temp readings mean very little.
