storm-chaser
Disabled
- Sep 2, 2011
- Upstate NY
This.VID is what the CPU calls for, not what you set in the bios.
Truth, as you confirmed, yes.
So are we all in agreement that VID can, in fact, be set from BIOS, as described in post #1 or am I missing something here?
On some new boards, yes.So are we all in agreement that VID can, in fact, be set from BIOS, as described in post #1 or am I missing something here?
You cant change that on older boards and cpu's, so no, the vid is still embedded in the cpu and is read by the mobo. It is a pre determined voltage range as set out by intel and programmed into the cpu so the mobo knows what kind of voltage to feed it at what clock speed, ie stock+turbo. I am not current on anything passed 3rd gen i7, so.. that's where my knowledge and guesstimation ends.
I do not know the reason why. Vdrop doesn't always exist. There could be none, or as I call it, vRaise. I've seen it on plenty of boards as well. But more so on older boards/CPUs.Okay, good deal. Last question. Can anyone explain why my actual voltage at the CPU is higher than what's set in the BIOS?
You would think due to vdrop the processor would reflect a lower voltage value in CPU-z, but in fact the opposite is true.
Is this just a software discrepancy?
