- Feb 17, 2010
- Manassas, VA
The Asetek unit IS more or less the H100. Corsair doesn't actually build their own liquid cooling units, Asetek manufactures it for them with some slight design tweaks. AFAIK, the H100 is better.
Don't get quad SLI. The fourth card adds almost no performance. And even though you might get it for bragging rights, the thing is that you can actually add something in that last PCIe slot that will actually make more of a difference in your computer. Especially if you plan on ordering high end speakers, I would much rather have a high quality sound card than a 4th GPU. A sound system has to be complete, a crap source and crap DAC is going to make good speakers sound like crap.
That being said, an actual quality 7.1 set is going to run you thousands of dollars. I'd go over to head-fi.com and ask there about speakers, that's the one of the biggest sound forums on the internet. That being said, they aren't as nice as we are over here, but they know what they're talking about. I'd also consider a high-end headset over a speaker setup.
RAIDing SSDs is more of a pain than it's worth, you also lose TRIM which helps the drives last longer. General rule of thumb is to get the single biggest SSD you can afford.
I wouldn't get the Velociraptors. The speed increase over the WD Blacks isn't worth the reliability decrease. 10,000 RPM drives tend to fail more often than others.
The 3960X is a HUGE waste. It's almost the same CPU as the 3930K, but $500 more.
The more RAM sticks you have, the more it might limit OCing. If you want tons of RAM, get 8GB sticks over 4GB sticks.
