TheGamer9991
- Sep 30, 2015
I recently decided to buy a custom pc for gaming and other high end usage (editing , etc).Here are the specs i have chosen.
( In case you can't find them online , i can post the links i found on request )
Processor ~ Intel Core i7 6700K
Motherboard ~ Asus Z170-K
Ram ~ G.Skill Ripjaws 4 Series 16 GB (2x8) DDR4 2400 Mhz
Graphics Card ~ Zotac Nvidia GTX 970 4GB
Hard Drive / SSD Hybrid ~ Seagate Hard Drive 2 TB SATA 6 GB with NCQ 64 Mb Cache
PSU ~ Seasonic S12II Series 520-Watt Power Supply
Cabinet ~ Circle CC 830 (With 3 inbuilt fans and I am buying one or two additional 120 mm fans )
Fan Controller ~ Thermaltake Commander FT
I am not mentioning monitors , optical drive , Wireless Adapter (wifi) , Keyboard , Mouse , Speakers as they are not relevant to my question.I will be buying most of my components from Amazon (India)
My only question is whether or not the hardware is completely compatible. Such as if all the components will fit in the case , all components are compatible with each other ,will there be space in the case for the additional fans , and if anything is not compatible , what would be an alternative choice for it.
Also , if there is any way to improve the build without changing the prices by too much , what would it be ?
All answers and suggestions are greatly appreciated.Thank you so much in advance.
