Lessthankeevin
- Jun 24, 2016
Putting together my first loop and I've been hardcore reading stickys and just posts in general. I can't find much information regarding a drain set however. My planned set up is:
Reservoir > pump > radiator #1 > monoblock > radiator #2 > gpu block > reservoir
My plan is to install a y-splitter between either "pump > radiator #1" or "radiator #1 > monoblock" as they're the lowest points in the system. The drain is going to have about a foot of soft tubing that's going to end with a valve.
Can someone shed some light on y-splitters and if there's spots where it's not ok to use them or just any recommendations in general. Thank you!
