Hi guys,
I have been trying to put together a schematic for the loop I will be building soon. I really need help deciding where to put my rads + fans and which direction they should be blowing. Please do excuse my drawing it really was the best I can come up with
Parts: (CPU cooler is just there for compatibility)
https://ca.pcpartpicker.com/user/Stripcell/saved/C79zK8
I have had these parts for a while. I just think it's time to water cool them since I got the poseidons and really think its time for me to put together my first water cooled computer! However, I have not bought ANY water cooling parts yet. So please feel free to suggest anything at all ( I live in Canada)
Schematic Picture:
The purple lines show the direction of flow and hopefully that will be in hard tubing. I might also change all the fans to pull and have them touching the case that way it will make it easier to connect all the fittings.
I am not really sure of the orientation of ANYTHING in this case so please feel free to comment on anything at all. Here is a description of what I have in mind in case the picture isn't clear enough and the reason why I came up with it:
Top:
360mm Radiator with 3x120mm Fans exhaust [SP]
Front:
280mm Radiator with 2x140mm Fans intake [SP]
I decided to make this as an intake because it seems like it would start pulling the intake air from the bottom right out of the case. Leaving the case with hardly any intake. I decided to put the radiator here instead of at the bottom because the 140mm will spin a bit slower with less noise than the 120mm in the bottom and also provide more surface area for cooling.
Bottom:
2x120mm Fans intake [HAF]
Seems like a good place to push air through the case. I think it would provide a good amount of air throughout the case.
Back:
120mm Radiator with 1x140mm Fan exhaust [SP]
I decided to put another radiator here instead of just a fan because I think that the system will need as many radiators as I can fit in the case!
Video Cards:
These cards still use their fans to keep the VRM cool and can not be switched off. So they will always be blowing some hot air.
PSU:
I am not really sure how to orient this ... Should I just keep it isolated?
I really hope this is the right place to post this .... and I really appreciate any help!! As I mentioned earlier, this is my first water cooling job so I really put this stuff together based on all the stuff I have read. So please feel free to offer help on any component or orientation.
Thanks in advance!!!
Schematic Picture:
Top:
Front:
Bottom:
Back:
Video Cards:
PSU:
