No. Dremels are pretty useless for long straight cuts, especially for thicker materials. Get a jigsaw with a metal smooth-cut blade or break down and buy yourself a scrollsaw. And buy lots of masking tape while you're there.JayoxD said:do you think a dremel can be used to cut through it because it feels like a pretty high grade aluminum.
Depends on how steady your hand is with the Dremel. Its going to take awhile and if you cant mantain a straight line itll come out all crooked and youll be unhappy you messed with your new case.JayoxD said:results will be the same right but its just dremel + time = jigsaw?
Frozencpu.com sells window molding and windows.JayoxD said:yea im thinking of just getting a jigsaw, so how would i cut it, should i just put the panel between the backs of 2 chairs, and drill a pilot hole and go from there? Then after how would i mount it? with like nuts and bolts and have the nuts facing the inside, so it does look bad?
really apreciate the help everyone
Just use bolts, I like Allen heads for this type of thing.JayoxD said:yea but i dont like the look of molding
