Hallo everyone,
I'm trying to setup a new system,
here are my specs:
-MOTHERBOARD: ASUS STRIKER EXTREME II 790 ULTRA SLI BIOS:1401
-CPU: QX9650
-VIDEOCARD: NVIDIA 9800GX2
-RAM: ddr3(corsair dominator PC3-12800 CL7)
-PSU: Enermax Galaxy 1000W
-COOLING:Phase
There is nothing I can do to overclock my CPU the way I want, I cannot get it stable over stock 3,00 Ghz.. and this seems really strange to me, since I'm under phase, and lots of people managed to get this chip 100% stable with same board over 4Ghz by air.
I was able to boot the system by setting the right Vcore all the way up till 5Ghz.. but i can't get it priming for more than a few minutes.
Over the 3.0 Ghz this is what happens when priming all 4 cores (Small FFT):
-Vcore to low: Rounding errors soon or later on all cores.
SLOWLY rising the vcore..
Rising the Vcore increases stability but as soon as all cores seem not to give any rounding errors in the first few mins, system suddenly resets or locksup when priming. What the hell?
Cpu temp is -20 sub zero (under load), it is not overheating.
All this happens if i raise the FSB and keep the 9x multiplier but also if i keep the FSB still and try to raise the multi.
As I said I can almost always boot into windows but i can never prime for more then 5 mins when overckocking.
CPU primes with no errors at all when @stock speed and voltage.
It's not my first overclock i've been using phase for several years and always achieved good overclocks...
By the way:
Memtest 100% OK.
Memory is working. Anyway I'm trying to get it stable using only a stick of ram.
Timings are not aggressive and voltage is OK.
Question:
Do you think it's possible that I might have used too much compund on the cpu?
here are my specs:
-CPU: QX9650
-COOLING:Phase
By the way:
Memtest 100% OK.
Question:
