- Dec 6, 2010
oooopsLooks like new!
Where's the before pics?
I'll have to give it a try. Even if I 'windex' with newspaper or lint free rags, it still leaves a residue/streaks on the car window (non smoker). To get past that, after a windex, I wipe the window with rubbing alcohol (sprayed on the rag as to not get it on the dashboard).For those that have not tried it, that Dawn Powerwash is the last thing you will ever need to clean windows and mirrors in your home and auto...zero streaking and no residue.
Is that for a SSD and Laptop HD?I got this
And it had dry flux on the PCB around the connectors, I used Dawn Power Wash to clean off the flux, Who knew
YesIs that for a SSD and Laptop HD?
What kind of connector does it use to hook up to your PC??? Is it sata ? ??
I get I had something like before it could hook up IDE SATA & SSD'S I don't know what I did with it.44 pin IDE to 40 pin IDE
44 pin IDE connector for 2.5 HHD/SSD
40 pin ATAIDE (PATA)
Oh, ok I just never herd of PATA before.2.5 and 3.5 HHD SATA drives all have the same connector so no need for adapter but with PATA 2.5 and 3.5 drives you do 2.5 44 pin to 3.5 40 pin.
Way to make me feel old!Oh, ok I just never herd of PATA before.
That was a long time ago.Way to make me feel old!
They were ribbon cables that connected the drives instead of the small SATA cables. You also had to deal with master/slave/primary/secondary/cable select jumper positions and such as well.
So much better nowadays
