Irregardless
- Aug 23, 2019
Im having major problems with my watercooling loop, and i am uncertain if it is the pump or simply user error, ive come across a few forum posts with similar problems, but the solutions that mostly have worked fro them have not worked for me. I Tried tilting the build an opening the top port on the res, but all was to no avail. The pump, as described in the video, moves the water once its beign filled the first time and* appears to pump out some air, but then it seems to stop working, Im not sure if something is blocking the flow, but it should not act like this.more details in the video*https://drive.google.com/file/d/1q3IpEw_ybBcRzqqf56ZVfWWHrg2RfWRB/view?usp=sharing
*i tested the pump outside of the unit with two radiators* in the loop without the cpu block. it did fill the radiatior but i am not sure if it is workin properly.* there is apparently issues with the pump and /or the cpu block
here are some more videos that i urge you guys to watch. Any help is appreciated
https://drive.google.com/open?id=0B7rX641j5xc2Q1plYmRwVXgtZDdLOVVMS0tqYjZpbjFiUlZZ
https://drive.google.com/open?id=0B7rX641j5xc2dGI5MnB5QUJxN2lVZEdRcGlBSTY1WVgybVFV
https://drive.google.com/open?id=0B7rX641j5xc2ajNHNDdPaldBYVpNSHZsZFIzVEttdkVQbTlF
