Are you sure its right? Verify in bios or ankther software.
If it is, adjust it back.
I always just set my timing and Dram voltage manually in BIOS.
What do you get if you set AI tuner from Auto to XMP ? Most DDR3 IC will handle the 1.65V easily
I'm not sure exactly which motherboard you have but I can see its an ASUS P6T. If it's the Deluxe then if you look at the bottom right of the motherboard you will see a jumper labeled OV_DRAM_BUS. Power down the system and switch the jumper to the 1-2 position. This will remove the Over Voltage setting from the DRAM and set it back to default (normal) voltage. This should allow you to set the DRAMv down to 1.35v.
EDIT:
On the P6T/P6T SE models the jumper is closer to the PCI slots
Try hwinfo64 and see what it is reporting.
