- Apr 30, 2012
- winter garden FL
so i was building a friend a gaming rig from the following parts.
m5a97 motherboard(no integrated graphics), fx6100 and a gigabyte 6850 gpu. 4x2gb ram out of his old gateway fx series.
so i put everything together, system boots everything runs all fans spins, and nothing shows up on the monitor(guaranteed working monitor). if the motherboard was defected, would it still turn on?
with the ram, the dram-led is always red, i pushed it for awhile and it flashes red, then goes back to constant red. could it be bad rams(non-compatible), or anything else that might be causing this problem?
no beep from the mobo while booting also, i did plug in the hd audio from the case (CM storm trooper)
