First, I apologize for the brash jump straight into asking for help or suggestions. I literally haven't visited a forum in nearly a decade and am sure at one point I had an account here, but can't recall the username or even have access to the email account associated with it.
I was recently talked into giving up on my Supermicro based Dually 1366 Rig, that by this time, had gone through 4 CPU Upgrades over it's lifetime ending at Dual X5670's.
With that in mind, you can safely assume that I haven't overclocked a system for 24/7 use since my X58 days and have owned the Dually setup locked at stock clocks for longer than the lifespan of most people's pets.
Now that my lack of current knowledge is out of the way.....
I was essentially 'given' (for what amounted to be beer money) a 7700K setup.
Prior to relinquishing the setup in question, my buddy was also kind enough to delid the CPU after performing the same on his new 9900K.
Here is now where I am at:
7700K (Delid) @ 5.0Ghz, 1.35V, LLC-4
Noctua U12S, Dual Fans
MSI z270 Gaming M5
32GB Corsair Vengance LPX @ 2400Mhz (8x4GB)
OCZ 650w 80+ (old model, but a spare I pulled fresh off my parts shelf)
Reference (Gigabyte) Radeon 7970 (I recently flashed to Ghz status & added UEFI)
The CPU has rarely seen 70c during Handbrake transcoding, holding on average @ 66-68c after hours of 100% use, as I use an AVX -1 offset.
I guess my question is, are there any other settings that might have eluded me, in order to get more from this setup ?
The current settings that I am employing should be pretty clear above.
On current settings, I have attempted 5.1Ghz with an AVX offset of -2, but have found stability issues and prior to throwing more voltage at things (as this is for mainly desktop and transcoding use) I figured I would ask those that are familiar with this setup for their input.
Thanks in advance.
Allan
MSI z270 Gaming M5
Thanks in advance.
Allan
