- Jul 12, 2012
- Athens,Greece
Hi guys,
So, after a few days I finally found some spare time to delidd an old E8600 I had. Everything went ok till now but I have 2 questions:
1) The dye was soldered on the IHS, that means it needed a bit of heating onto the IHS with a pencil torch. In a small area around the dye (on the pcb), I can find small bubbles (sign of the lacquer used over the pcb to have been overheated). Will that cause any problem? The pcb is untact though.
2) How do I remove the solder from the dye and from the IHS? I tried to remove it with my fingernail but it's too damn nasty and it won't come off totally :S
Thx in advance
Thx in advance
