Hi,
I bought a Dell of the shelve, I know, what an idiot. As you can probably guess it is not very customizable at all. When I try to run nTune the machine crashes. I can run MSI Afterburner but can not adjust the core voltage and it seems that adjusting everything else doesn't improve anything and eventually makes the screen stutter or go blank. There are no BIOS settings for CPU speed or fans. I can adjust the graphics card fans with Afterburner though.
What would be the simplest way to be able to overclock the CPU and GPUs and adjust the fans. A new motherboard? Would that even help? If I did that would I even be able to overclock the GPUs easier?
The answer would have been not to get a Dell but its to late for that no. My end goal is the squeeze and much performance out when needed and make the machine as quiet as possible at all other times.
Any advice would be appreciated.
Thanks,
Eds
Thanks,
Eds
