Jess1313 said:ATM my cvore seems strong, many be at times(idle), .02 volts under, but it seems to almost increase under aload
Xaggerate said:CPU-Z reports 1.472-1.488, bios reports 1.48-1.50....so it's not so bad...
dreIU said:EDIT: Jess, is that bios you modded (that also fixes the temp issue) in this thread somewhere?
dreIU said:Don't the desktops need 1.55vcore to run?
also the only really way to know is to measure directly on the mobo,w/ a Digita multi meter, on the base of the Chocks. i have done this, an the voltage is stronge. just be VERY CAREFUL if you do this, there are very many compontates around there, many involved the the Vcore circuit, and if anythink was shorted, then your could lose a mobo, and a cpu.Xaggerate said:CPU-Z reports 1.472-1.488, bios reports 1.48-1.50....so it's not so bad...
Xaggerate said:ALMOST memtest stable @ 280x9....w/ the following settings:
3.0v vdimm
1.66v vcore
stock northbridge voltage....
Still working on it...gonna try 3.1v...maybe increase the northbridge...but I can't POST with anything greater than 270fsb without increasing vcore...
Jess1313 said:heres the 3.8+vdimm bios, modded by Jess1313 . i didnt do the temp fix, nor the TT fix(this goes to oscar at DFI-street), but i did do the vdimm opions above 3.1vdimm. but they dont work unless you have a modded 3.3vrail. i need 3.74v on my 3.3vrail to get 3.6vdimm opion to work in bios. its just because there isnt enought voltage there for the IC to give
dreIU said:Great thanks, you did say that you just used winflash, right?
dreIU said:EDIT: 250x10 sounds good, but I thought you were going for higher HT than that (or are you still working on it?)
Xaggerate said:Looks like it's the end of the road....
Got to 280...can't past memtest #5 with 1.8v chipset, 3.1v vdimm, and 1.67v vcore...
Do you think I can get away with 113% (1.71ish) on the vcore..or am I pushing it?
Jess1313 said:you got water on that chip right?
dreIU said:either way, I think that it is OK... from what I have read, I understood that 1.7ish is the limit for air. That is the max I would go (well, 1.71 in his case is OK too IMO).
EDIT: jess, thanks for the explanation in post 134!
