- Nov 23, 2005
- Reading, PA
Ok guys. I got my EVGA 8800GT SC 3 days ago. I was able to bag a 14220 in 3DM06 with it clocked to 730/1800/1000. With the fan set to 60% in Rivatuner, temps would get no higher then 66C. 3DM06 would go through with no problems or errors. I then began playing some games, Crysis Demo, HL2: Deathmatch, etc. and started to get some driver errors every few minutes. Game would play fine and then all of a sudden stutter and stop. I'd then get the "Display driver nvlddmkm stopped responding and has successfully recovered." error. So, I decided to clock down a bit.
I first took it down to SSC speeds (700/1728/1000) thinking the card should be able to pull these off fine. I load the settings, play a few minutes of a game, and the error was right back. Doing a little research, I came upon JohnnyGuru's post on HardForums about the RAM clocks on these cards so I decided to take the RAM down to 975 Mhz. No dice. Took it down to 950, and still got errors. Keep in mind 950 is the stock speed for the SC. I started to drop the core clock down, and even with it at 675Mhz and the shader at 1680, I was still getting the driver errors.
Just to see, I then took the card back to stock speeds. After playing a few hours, I did not get one hangup or error. Ok, so the card will run at stock but after seeing all the OC's people are getting both on here, EVGA forums, and XS, this card should be capable to at least game at SSC speeds without errors. Thing is, I'm not sure if it's a problem with the card or the simple fact that the drivers are still so young for this thing. With my old EVGA 8800GTS 640 SC I had no issues at all in 4 months of use while OC'd so I'm thinking drivers aren't the issue here.
Any help or insight you guys could give me would be much appreciated. Thanks guys!
