H100?
Here's my badly drawn images:
View from the bottom of the radiator. Grey area is the fins/heatpipes, all surrounded in a white box that has holes to mount two fans to.
Grey area is fins/heatpipes on top of the CPU, heatpipes rise up to radiator inside of white box.
Grey area is fins/heatpipes on CPU, heatpipes bend to meet the fan mounts for the top of the case.
could it be this??? http://ksstudios.com/silverstone-nt01-e-cpu-cooler
That doesn't quite fit your description of "bolting to the case" or "using 120 or 140mm fans". But if you found it, neat. Actually looks like a decent cooler, but pretty spendy.
If it wasn't so expensive, that would work good in custom built rackmounted servers.
It doesn't cool as well as the stock heatsink.
Better than those two: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065$50 + $10-20 for a couple of 60mm fans. It would probably work very good, but yeah.
In reality though, I was actually looking at these two coolers:
Antec - Like the price.
Zalman - Like the looks.
That was without fans, if I read the review correctly.
yep...without fans it was a little worse than a stock cooler...very impressive to me honestly.
