Hey guys, just ordered some parts for a new build, for the longest time I was going for a 3200mhz Ram kit. But what's that I see right next to the ram kit I am looking at? a 3600mhz kit at the same price? Fo' sho' (Not how it went down btw). 1st up didn't check CL timing's, 3200-16cl and 3600-18cl (same same from what I can tell).
What I also didn't think about, was checking if it was compatible with my motherboard, MSI B450a pro max (Ryzen5 3600 is the cpu is that also helps).
Looking into it it doesn't seem the Motherboard "supports" the ram I've chosen. Just wondering how much I may have screwed up if at all? All I've been hearing is "Ryzen loves fast ram" the faster the better I thought?
It looks like I might be able to get around it with a Mobo Bios upgrade, (never done one before, but it looks simple enough).
What should I expect to see just plugged in out of the box?
What should I expect if I enabled XMP (Or amd equivalent)?
What should I expect after a bios upgrade?
Links to parts below.
Thanks for any help.
Ram 3200mhz - https://www.newegg.com/global/au-en...-ddr4-sdram/p/N82E16820233894?&quicklink=true
Ram 3600mhz - https://www.newegg.com/global/au-en...-sdram/p/N82E16820236596?Item=N82E16820236596
Mobo - https://www.msi.com/Motherboard/B450-A-PRO-MAX
