Not really a fan of RGB kits. I'd end up just turning off the RGBs with software given the opportunity. Was recommended the Corsair Vengeance RGB Pro 32GB (https://www.newegg.com/corsair-32gb-288-pin-ddr4-sdram/p/N82E16820236607?Item=N82E16820236607) on my new build thread, but was wondering about moving away from the RGBs. Plus, I don't want to worry about clearance with the Noctua NH-D15 (having to move to the NH-D15S, or removing the front fan from the D15). What are some similar options? Would it be as easy as moving to something like the Corsair Vengeance LPX (https://www.newegg.com/corsair-32gb-288-pin-ddr4-sdram/p/N82E16820236596), as the specs look the same?
