- Jun 10, 2013
- Las Vegas
- Thread Starter
- #21
Don't get the XSPC res, those stupid things are known to leak, i had one that was soo poorly made, the top was visibly warped and leaked a decent amount of coolant. just save yourself the trouble and avoid it all together. Go for the monsoon one, i have one of those in my rig now, and its so freaking awesome i wish i just got it from the start.
I read about those issues with this res - I'm getting a 'newer' one but am fully aware of this possibility. Thanks for the heads up. Conumdrum and I were discussing the Monsoon in some PMs, and it will most likely be my next res. Assuming no issues with the XSPC, I'll swap it out when I do my next WC loop to an older computer. Monsoon is definitely a beast of a res! Sexy as balls
You could save a lot of money by not water cooling the GPU, with the limited voltage increase NVIDIA allows on their cards now days, they'll never even sniff dangerous temps with partner card air coolers that have been developed.
That's a really good point, and I can always add a water block or buy gpu w/ block and add to my loop at a later time. This build may turn into just cooling the CPU for the time being if I can't get my 'optimal' liquid cooling GPU solution for a reasonable price within the next month or so.
if you're going to use the rear fan as air in, you'll need a dust filter.
Besides that, you're doing good
A big plus one on the filtered intake air. I run 3 200's and 1 120 intake fans, filtered with DEMCiflex Magnetic filters on my CM HAF 922 case. Been running 24/7 for over 90 days now with positive pressure and not a speck of dust inside. Exceeded my expectations.
All of the fan inlets on the NZXT 630 have fan filters, but probably not the exhaust like you mentioned! Good catch - and you're right, I'll be picking up a dust filter for that rear fan when I'm running it as intake. I'll check out the magnetic filters, they sound promising! Thanks!!
