One version is $189 and the other is $400 (on sale now for $270)
$189 ASUS Sabertooth
$400 ASUS Sabertooth
Amazon prices are screwy dude. Current Sabretooths are about 220 on the AMD side for the 990FX while the intel ones (there are 2 1155 Sabretooths the cheaper one has garbo power phasing) are between 180 and 230 afaik. None are 400. They are not absolutely top tier motherboards. 400 bucks is a top end 'extreme' version ROG board if you're buying from ASUS on the desktop end of things.
Tough decision for me between the Crosshair V and the Sabertooth
I've read great things about both boards. I have read that the Crosshair V has had some issues with breaking while being shipped and that the board despite it's high performance is kind of fragile,
1. I haven't bought a board in years due some associations that exist no longer.
2. Due #1, I too do a lot of reading and looking for the truth in the middle of all the rah rahs and blah blahs. That said I have begun to read that Gigabyte is the better fitted motherboard and that Asus has become fragile.
3. Following with #2 above, I would certainly n0t go with what some say is a more fragile board and bang my bucks for the SaberTooth as I do still like the Asus bios and the fact they do try to give the most out of a chipset. Yep opinions are like noses, we all got 'em.
Luck man and happy putering, you likely will n0t lose no matter your real choice of board in the Asus line-up as long as you don't buy the cheapest thing and then plan to overclock 'er.
Yep that is a problem with this new stuffz every time you turn around.
I see you got a 1090T...let us know if it is easier to get up to speed with the new 990FX board. RGone...ster.
