- Aug 11, 2015
Got around to playing with some overclocking on my new FX-8370 chip which replaced a failed 8350. I was happy to see a stock VID of 1.30 on the new 8370 compared to the stock VID of 1.38 on the old 8350. Currently have the 8370 running at 4.6 Ghz at 1.34 Vcore and end up around 52 C. when crunching on all cores in BOINC Manager. I got the chip to run at 4.8 Ghz at 1.37V but that put me at 62 C. when fully loaded in Prime95 or OCCT. I don't want to run that hard, that close to max core temps in daily driving or crunching, so I backed on down to 4.6 Ghz. I am cooling with a Corsair H105 AIO but with Noctua NF-F12 fans instead of the stock Corsair fans. I know that the Corsair fans push more CFM but with more or less equivalent pressure compared to the Noctuas. I didn't like the noise level of the Corsair fans so I substituted the Noctuas for a quieter cooler. In retrospect, the AIO fans are the least contributor to the overall noise level of system because the fans on the dual GTX970's are the greatest producers of noise and drown out any noise from the CPU cooler. Does my temps at 4.8 Ghz appear reasonable for the necessary Vcore voltage and current cooling capabilities? Does any one believe that I would achieve better temps at 4.8 Ghz with the stock Corsair fans? If somebody jumps in here with an opinion that it wouldn't help much, I'd appreciate it for avoiding taking the system apart again to replace the fans. I'm just trying to determine whether I should invest any more time in trying to overclock the new 8370 chip. I spent about 6 hours last night to get to 4.8 Ghz and stable with no math errors. That is my prime concern, to produce good science results. I don't game. Opinions?? Thanks in advance.
Cheers, Keith
Cheers, Keith
