Video 8800 GT, CPU E8400
Crysis bench
2.5 Ghz
/14/2008 5:31:58 PM - XP
Beginning Run #1 on Map-island, Demo-benchmark_gpu
DX9 1024x768, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Demo Loops=3, Time Of Day= 9
Global Game Quality: High
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 44.62s, Average FPS: 44.82
Min FPS: 10.91 at frame 145, Max FPS: 65.96 at frame 953
Average Tri/Sec: 44331952, Tri/Frame: 989119
Recorded/Played Tris ratio: 0.93
!TimeDemo Run 1 Finished.
Play Time: 36.61s, Average FPS: 54.63
Min FPS: 10.91 at frame 145, Max FPS: 70.81 at frame 998
Average Tri/Sec: 54639328, Tri/Frame: 1000182
Recorded/Played Tris ratio: 0.92
!TimeDemo Run 2 Finished.
Play Time: 36.54s, Average FPS: 54.73
Min FPS: 10.91 at frame 145, Max FPS: 72.56 at frame 101
Average Tri/Sec: 54830404, Tri/Frame: 1001749
TimeDemo Play Ended, (3 Runs Performed)
Completed All Tests
<><><><><><><><><><><><><>>--SUMMARY--<<><><><><><><><><><><><><>
6/14/2008 5:31:58 PM - XP
Run #1- DX9 1024x768 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 54.68
3.16 Ghz it levels off for my video card
6/14/2008 9:29:50 PM - XP
Play Time: 39.49s, Average FPS: 50.65
Min FPS: 26.46 at frame 141, Max FPS: 69.36 at frame 985
Average Tri/Sec: 50073764, Tri/Frame: 988601
Play Time: 33.95s, Average FPS: 58.91
Min FPS: 26.46 at frame 141, Max FPS: 72.73 at frame 100
Average Tri/Sec: 58929808, Tri/Frame: 1000310
Play Time: 33.94s, Average FPS: 58.93
Average Tri/Sec: 59007240, Tri/Frame: 1001288
Completed All Tests
If i had SLI it whoud be better.
Crysis bench
2.5 Ghz
Completed All Tests
Completed All Tests
Crysis is a demanding game, I only have a $175 8800 Gt and my frame rates drop to much, if i had more money to spend i would get a better graphics card or two, the graphics card is holding me back real bad, I did have a cheaper graphics card and i had to run on medium to low and the graphics sucked in crysis, so I'm vary content now.Can you run it at a higher rez? You might as well run 3DMark06 if you're going to run at that rez.
There's no point in buying a high end graphics card if you're going to run 1024x768.
Download Crysis_Benchmark_Tool- http://downloads.guru3d.com/download.php?det=1791OK how do I run the tests like this ? I have a Q6600 with 2 8800gt's in SLI and can run 1680X1050 I have Crysis and lost planet extreme condition.
Then why did you get the GTS that must be a waste of money for you? Thanks for saying that, it makes me feel good that i did not purchase a GTSwingman, I'm not sure why your having so much trouble running the benchmark at higher rez. It ran fine on my 8800GT, before I got my GTS. I was only getting about a 3fps difference b/n the 2 cards.
Because in real world gaming you need a low rez to get Some decent FPS in crysis with 8800GT.I'm still not sure what you're trying to prove showing all these low rez bench's which are obviously going to be more CPU dependent than running at a higher rez.
What purpose does that serve, they have $600 video cards for that.Can you do me a favor and just run at 1680x1050 at different CPU speeds (only changing the multi)? It doesn't matter how low the fps are...you're not actually playing...I just want to see what happens. Or even try running 1400x1050 at some lower CPU speeds.
jason what point are you trying to make
A=Spend more money on your cpu than your video card.
B=If you don't have much money buy a cheap dual and a cheap video card.
C=Maybe buy vary expensive quad and a vary expensive 2 x video cards.
D=Save your money on the quad get a cheep dual and vary expensive 2 X video cards.
My point is if your in the intel CPU post and you want to save money, get dual core cpu for games, also if you run crysis overclock the CPU and adjust your video card for acceptable frame rates, I think the industry standard is 30 FPS minim.
3.0Ghz E8400
8/3/2008 3:10:23 PM - XP
DX9 1400x1050, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Demo Loops=2, Time Of Day= 9
Play Time: 54.91s, Average FPS: 36.42
Min FPS: 23.86 at frame 140, Max FPS: 43.57 at frame 1786
Average Tri/Sec: 35907204, Tri/Frame: 985808
Play Time: 51.15s, Average FPS: 39.10
Min FPS: 23.86 at frame 140, Max FPS: 45.61 at frame 984
Average Tri/Sec: 38939520, Tri/Frame: 995847
TimeDemo Play Ended, (2 Runs Performed)
Completed All Tests
Run #1- DX9 1400x1050 AA=No AA, 32 bit test, Quality: High ~~ Last Average FPS: 39.10
This is real world pic with crysis below at minim 18 FPS 1600X1200 and the game play sucks at that res, O sure it's fine when nothing is shooting at you.
My question is:
I am trying to build (or already built - just deciding on what CPU to leave in there) an HTPC. Should I use a Q6600 G0 or an E7200? (I have both available and probably will sell the one I don't use) I will most likely give it a nice overclock, but nothing crazy.
I don't know much about video/audio editing and whatnot, but want to get into storing many many movies on that machine. It's in a mid-tower case with plenty of airflow, 2gb of ram (could always dump 4gb if needed), plenty of HDD space on a raid5, and a 550W Antec that should hold up well.
