- Feb 22, 2009
- NYC
Very nice build going on. Subscribed!
that is a nice clean look. excellent short loop.
I loled when I realized you had printed out the MOBO to test build. THat was kinda awesome
ok wow. that's also awesome.
Very good choice of parts!
I do have my reservations about the gold, though. If it's only on the outisde then that's good.
If it's in contact with the water then that's not so good ...
Well, that all depends on how you define "reactive". The thing with WC loops isn't so much how reactive the metal is with the water, it's how reactive it is with the other metals in the loop. That's why we all say copper and aluminum don't mix because their anodic index difference is 0.40, which means you'll have galvanic corrosion problems. This brings up the point I was making with gold. As you pointed out most of our loops are copper. Copper has an anodic index of 0.35 and gold has an index of 0.00 making the 0.35 difference very close to the copper/aluminum difference. In other words, copper with gold is almost as reactive (as far as galvanic corrosion goes) as copper with aluminum. That's not good.
I've seen their gold-plated fittings as well. If the gold doesn't contact the water then everything is fine but if it is in contact with the water then whoever thought that up over at Ek should be shot. It may also be why the gold was cheaper than the full copper ...
Gold doesn't oxidize very easily if that's what you mean and because of it's atomic structure it can resist some acids but that doesn't mean it's as chemically neutral as, say, neon. Gold is still a metal and it's even a good electrical conductor, which means it can exchange electrons fairly easily ...I was under the impression that gold is resistant to corrosion and like nickel is suitable for plating.
